Configure the originator ID to set the Rendezvous Point (RP) address inside the Source Active
(SA) message. The RP address must be a pre-configured CLIP interface on the global
router or a VRF. The RP address is also the local IP address in all peer relations.
![Note](images/note.png)
To delete the originator ID, you must first disable MSDP.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ip msdp originator-id 2.0.2.2
Variable definitions
The following table defines parameters for the ip msdp originator-id command.
Variable |
Value |
{A.B.C.D} |
Specifies the MSDP source IP address. The IP address must be one of the CLIP interfaces configured on the global router or a VRF. |
