Use the following procedure to automatically reactivate the port
that is shut down by the SLPP.
- In the Device Physical
View tab, select a port.
In the navigation pane, expand
- Click General.
- Click the CP Limit tab.
- Select AutoRecoverPort to activate auto recovery of the port from the action taken by SLPP
shutdown features. The default value is disabled.
- Click Apply.
