This attribute is used in packets transmitted to the RADIUS server to inform that the current authenticated MAC is associated to a FA Client of type x. This attribute is defined under Nortel vendor id (562) and uses the value 182.
Only one FA Client per port is supported.
The following values are defined for FA Client type:
Any integer value provided by the FA is sent to the RADIUS server without any check from the EAP application.
