The switch supports private VLANs and E-Tree configuration. MLT and private VLANs operate as follows:
When using static MLT, configure the private-vlan as part of the overall MLT configuration, not at the port member level. All ports in the MLT use the private VLAN type for that MLT.
When using LACP, configure the private-vlan at the interface level.
When the private VLAN port type is trunk, the MLT automatically becomes tagged.
If there are other non-private VLANs using the MLT configured as isolated, the following message is displayed: All non private VLANs using this interface will be removed once this mlt becomes isolated. Do you wish to continue (y/n) ?
If there are other non-private VLANs using the MLT configured as promiscuous, the following message is displayed: All non private VLANs using this interface will be removed once this mlt becomes promiscuous. Do you wish to continue (y/n) ?
