This procedure only applies to the VSP 7400 Series.
Perform this procedure to view remote IS-IS adjacency information. The platform sends IS-IS Hello (IIH) packets to discover IS-IS neighbors and establish and maintain the IS-IS adjacency. The platform continues to send IIH packets to maintain the adjacencies that the system establishes. For two nodes to form an adjacency the B-VLAN pairs for the primary B-VLAN and secondary B-VLAN must match.
 - Select IS-IS Remote.
 - Select the Adjacency tab.
Adjacency Field Descriptions
Use the data in the following table to use the Adjacency tab.
 Name  |
 Description  |
                                 Interface  |
                                 Specifies the remote IS-IS interface on which the adjacency is found.  |
                                 Level  |
                                 Indicates the level of the remote IS-IS interface (Level 1 [default] or Level 2).  |
 State  |
 Specifies the state of the adjacency:
                                 LastUpTime  |
                                 Indicates when the adjacency most recently entered the state up, measured in hundredths of a second since the last re-initialization of the network management subsystem. Displays 0 if the adjacency has never been in state up.  |
                                 NeighPriority  |
                                 Specifies the priority of the neighboring Intermediate System to transition to the Designated Intermediate System.  |
                                 HoldTimer  |
                                 Specifies the holding time in seconds for this adjacency. This value is based on received IS-IS Hello (IIH) PDUs and the elapsed time since receipt.  |
                                 NeighSysID  |
                                 Specifies the system ID of the neighboring Intermediate System.  |
| AdjHostName |
                                 Specifies the host name listed in the LSP.  |
| ParallelActive |
                                 Specifies if the current adjacency among all the parallel adjacencies between two nodes is active. The values are:
