  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Select IKE.
  3. Select Globals tab.
  4. In the CertIdentitySubjectName field, enter the digital certificate subject name use as identity certificate.
Globals Field Definitions
Use the data in the following table to use the Globals tab.
Name Description
Specifies the digital certificate subject name use as identity certificate in IKE.
