  • The system supports reverse path checking only on ports that have a valid IP address.
Configure reverse path checking on a port to determine if a packet IP address is verifiable. Use reverse path checking to reduce the problems that are caused by the introduction of malformed or forged (spoofed) IP source addresses into a network. After you enable reverse path checking, the switch performs a reverse path check to determine if the packet IP address is verifiable. If the address is not verifiable, the system discards the packet.
Reverse path checking operates in one of two modes:
  • exist-only mode
  • strict mode
  1. In the Device Physical View tab, select a port.
  2. In the navigation pane, expandConfiguration > Edit > Port.
  3. Click IP.
  4. Click the Reverse Path Checking tab.
  5. Select the Enable check box to enable reverse path checking.
  6. Select exist-only or strict.
  7. Click Apply.
Reverse Path Checking field descriptions
Use the data in the following table to use the Reverse Path Checking tab.
Name
Description
Enable
Enables reverse path checking on the selected port. The default is disabled.
Mode
Specifies the mode for reverse path checking. The modes are
  • exist-only—reverse path checking checks whether the incoming packet source IP address exists in the routing table. If reverse path checking finds the source IP entry, the packet is forwarded; otherwise the packet is discarded.
  • strict—reverse path checking checks whether the incoming packet source IP address exists in routing table. If reverse path checking does not find the source IP entry, the packet is dropped; otherwise, reverse path checking further checks if the source IP interface matches the incoming interface of the packet. If they match, the packet is forwarded; otherwise the packet is discarded.
The default is exist-only.
