Initiate a Layer 2 Traceroute
![Note](images/note.png)
This procedure does not apply to XA1400 Series.
Use this procedure to trigger a Layer 2 traceroute. This feature enables CFM to debug Layer 2 in an SPBM cloud or network. It can determine the path used by IS—IS to get from one MEP to another, by showing all the hops between. Therefore, it can show where connectivity is lost. It can also work for IP shortcuts.
If you configure IsTraceTree to false then EDM performs Traceroute on the unicast path. If you configure IsTraceTree to true then EDM performs TraceTree on the multicast tree.
For more information on configuring tracetree, see Configure a Layer 2 Tracetree.
![Important](images/important.png)
Important
To trace a route to a MAC address, the MAC address must be in the VLAN FDB table.
For B-VLANs, you do not have to trigger an L2Ping to learn the MAC address because IS-IS populates the MAC addresses in the FDB table.
Linktrace traces the path up to the closest device to that MAC address that supports CFM.
On the source and destination nodes, you must configure a CFM MD, MA, and MEP, and assign a nodal MEP to the B-VLAN.
- Select L2Ping/L2Trace Route.
- Select the L2 Traceroute/TraceTree tab.
- To start the traceroute, highlight an entry, and then select Start.
- To update the traceroute, select Refresh.
- To stop the traceroute, select Stop.
L2 Traceroute/TraceTree Field Descriptions
Use the data in the following table to use the L2 Traceroute/TraceTree tab.
Name |
Description |
VlanId |
Specifies a value that uniquely identifies the Backbone VLAN (B-VLAN). |
Priority |
Specifies a 3–bit value to be used in the VLAN header, if present in the transmitted frame. The default is 7. |
DestMacAddress |
Specifies the target MAC address. |
HostName |
Specifies the target host name. |
DestIsHostName |
Specifies whether the host name is (true) or is not (false) used for the L2Trace transmission. |
Isid |
Specifies the Service Instance Identifier (I-SID). |
IsTraceTree |
Specifies whether the multicast tree or unicast path is traced:
Status |
Indicates the status of the transmit loopback service:
This field is also used to avoid concurrency or race condition problems that can occur if two or more management entities try to use the service at the same time. The default is ready. |
ResultOk |
Indicates the result of the operation:
The default is true. |
Ttl |
Specifies the number of hops remaining to this L2Trace. This value is decremented by 1 by each Bridge that handles the L2Trace. The decremented value is returned in the L2Trace. If 0 on output, the L2Trace is not transmitted to the next hop. The value of the time-to-live (TTL) field in the L2Trace is defined by the originating MEP. The default value is 64. |
SourceMode |
Specifies the source mode:
The default is 1: nodal. |
SeqNumber |
Specifies the transaction identifier/sequence number of the first loopback message (to be) sent. The default is 0. |
Flag |
L2Trace result flag that indicates L2Trace status or error code:
