View IP Source Guard (IPSG) configuration on a port, with filters for IPv4 addresses.
  1. To enter User EXEC mode, log on to the switch.
  2. View IPSG configuration:
    show ip source verify interface gigabitEthernet [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}]
Switch:1>show ip source verify interface gigabitEthernet 4/1
                             Source Guard Port Info
PORT                     IPSC
NUM        ENABLE        ORIGIN
4/1        true          RADIUS
All 1 out of 1 Total Num of Ip Source Guard entries displayed
The following table defines parameters for the show ip source verify interface gigabitEthernet command.
Variable
Value
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
