This procedure only applies to the VSP 7400 Series.
Configure manual-area in both home and remote area.
- Configure the Shortest Path Bridging MAC (SPBM) instance and backbone VLANs (B-VLAN) manually.
- Configure the nickname in both home and remote area manually.
Disable Auto-sense on the port.
Make sure that the physical node nickname, virtual node nickname and system ID are different.
Perform this procedure to enable remote Intermediate-System-to-Intermediate-System (IS-IS) interface on the selected port(s).
When the switch receives a Fabric Connect TLV through LLDP on a port that has remote IS-IS enabled on it, the port transitions to the Auto-sense NNI pending state. For more information, see Auto-sense Port States.
Enabling remote IS-IS interface on port 1/2:
Switch:1>enable Switch:1#confiure terminal Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)isis remote enable
The following table defines parameters for the isis remote command.
Variable | Value |
enable |
Enables a remote IS-IS interface on the selected ports. |
