This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure layer 2 I-SID list.
- Select MultiArea.
- Select the L2 ISID List tab.
- Select Insert.
- Configure the layer 2 I-SID list parameters.
- Select Insert.
L2 I-SID List Field Descriptions
Use data in the following table to use the L2 I-SID List tab.
Name | Description |
Name |
Specifies the name of the layer 2 I-SID list. |
RangeStart |
Specifies the I-SID value as the starting range for the layer 2 I-SID list. |
RangeEnd |
Specifies the I-SID value as the ending range for the layer 2 I-SID list. |
