![Note](images/note.png)
This procedure only applies to XA1400 Series.
Use the following procedure to configure Fabric Extend (FE) over IPsec.
The tunnel source IP address can be a brouter port IP, a CLIP IP, or a VLAN IP.
Configuring Fabric Extend over IPsec consists of two primary tasks: configuring the tunnel source address and configuring the logical interface. These tasks must be completed on both ends of the tunnel.
For information about how to configure an IPsec NAT-T Responder, see IPsec configuration using CLI.
Switch A Steps
Switch B Steps
The following table defines parameters to configure Fabric Extend (FE) over IPsec on a device.
The following table defines parameters for the ip-tunnel-source-address command.
Variable |
Value |
<A.B.C.D> |
Specifies the IS-IS IPv4 tunnel source address, which can be a brouter IP, a CLIP IP, or a VLAN IP. |
vrf WORD<1–16> |
Specifies the VRF name associated with the IP tunnel. |
Variable | Value |
<1–255> |
Specifies the index number that uniquely identifies this logical interface. |
<A.B.C.D> |
Specifies the IS-IS IPv4 tunnel source address, which can be either a brouter interface IP or a CLIP IP. |
name WORD<1–64> |
Specifies the administratively-assigned name of this logical interface, which can be up to 64 characters. |
mtu <750–9000> | Specifies the Maximum Transmission Unit (MTU) size of each packet. The default MTU value is 1950. |
The following table defines parameters for the isis command.
Variable |
Value |
enable |
Enables or disables the IS-IS circuit/interface on the specified port or MLT. The default is disabled. Use the no option to disable IS-IS on the specified interface. |
spbm <1–100> |
Enable the SPBM instance on the IS-IS interfaces. |
The following table defines parameters for the auth-key command.
Variable |
Value |
WORD<1–32> |
Specifies the authentication key on the assigned logical interface if using a pre-shared key. Use the no option to disable the authentication key on the specified interface. |
The following table defines parameters for the ipsec command.
Variable |
Value |
auth-method <pre-share | rsa-sig> |
Configures the authentication method for IPsec. The default is a pre-shared key. Use rsa-sig to use an installed digital certificate instead. |
encryption-key-length <128 | 256> |
Specifies the IPsec encryption key length for FE tunnel, which is 128 bit or 256 bit. The default IPsec encryption key length value is 128 bit. |
