Transparent Port UNI (T-UNI) maps a port or MLT to an I-SID. Transparent Port UNI configures a transparent port where all traffic is MAC switched on an internal virtual port using the assigned I-SID. Multiple ports on the same unit and on other Backbone Edge Bridges (BEBs) are switched on a common I-SID. No VLAN is involved in this process. The T-UNI port is not a member of any VLAN or STG.
Use the following procedure to associate a port and MLT with an I-SID.
You must configure Transparent Port UNI. For more information, see Configuring Transparent UNI.
You must associate a T-UNI LACP MLT with a VLAN before mapping the LACP MLT to a T-UNI I-SID.
Caution
Ensure that a T-UNI LACP MLT is always associated with a VLAN (even if it is the default VLAN) before adding it to a T-UNI I-SID. Otherwise, traffic is not forwarded on the T-UNI LACP MLT.
- Select ISID.
- On the Service tab, select a row with the type configured as elanTransparent.
- Select ELAN.
- Select port members.
- Select MLT Ids.
- Select Apply.
Elan Transparent field descriptions
Use the data in the following table to use the Elan Transparent tab.
Name |
Description |
PortMembers |
The set of ports that are members of the elanTransparent service type. From the ports available, you can select single or multiple ports. |
MltIds |
The set of bits that represent the MLT Ids. From the MLTs available, you can select any, or all of the MLTs to be a part of elan transparent i-sid . |
