Configure ACE IP destination address entries to have the filter look for specific destination IP addresses.
  • The ACL exists.
  • The ACE exists.
  1. In the navigation tree, expand the following folders: Configuration > Security > Data Path.
  2. Click Advanced Filters (ACE/ACLs).
  3. Click the ACL tab.
  4. Select the appropriate ACL.
  5. Click ACE.
  6. Select the appropriate ACE.
  7. Click IP.
  8. Click the Destination Address tab.
  9. Click Insert.
  10. Specify the operation type.
  11. In the IPAddr box, enter the destination IP address.
  12. Click Insert.
Destination Address field descriptions
Use the data in the following table to use the Destination Address tab.
Name
Description
AclId
Specifies the ACL ID.
AceId
Specifies the ACE ID.
Oper
The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.
IPAddr
Specifies the destination IP address.
OperMask
Specifies the mask value for the destination IP address.
