Change an existing configuration using a table-based tab. You cannot edit grey-shaded
fields in the table. The following procedure is an illustration on how to use a
table-based tab.
![Note](images/note.png)
You can expand the appropriate folders for any feature you configure and select a
table-based tab.
- In the Device Physical
View, select multiple ports.
- In the navigation pane,
expand the folders.
Select the VLAN tab.
The system displays a table-based tab with the VLAN information.
- Select a table-based
tab.
- Double-click a white-shaded
field to edit the value.
Select the arrow in the list
field to view the options, and then choose the appropriate value.
Double-click a text-entry field
and edit the value.
Select Apply to save the
configuration changes.
