Use the port lock feature to administratively lock a port or ports to prevent other users from changing port parameters or modifying port action. You cannot modify locked ports until you first unlock the port.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Click General.
  3. Click the Port Lock tab.
  4. To enable port lock, select the Enable check box.
  5. Click Apply.
Port Lock field descriptions
Use the data in the following table to use the Port Lock tab.
Name
Description
Enable
Activates the port lock feature. Clear this check box to unlock ports. The default is disabled.
LockedPorts
Lists the locked ports. Click the ellipsis (...) button to select the ports you want to lock or unlock.
