Assign an NTP key to use MD5 or SHA1 authentication on the server.
- Select NTPv4.
- Select the Key tab.
- Select Insert.
- Complete the fields.
- Select Insert.
Key Field Descriptions
Use the data in the following table to use the Key tab.
Name |
Description |
KeyId |
Specifies the key ID that generates the MD5 or SHA1 digest. |
KeyType |
Specifies the type of authentication as MD5 or SHA1. The default is MD5 authentication. |
