Use this procedure to enable IPv6 static RP.
  1. In the navigation pane, expand the following folders: Configuration > IPv6.
  2. Click IPv6 PIM.
  3. Click the Globals tab.
  4. Select sm (sparse mode).
  5. Select Enable.
  6. Select Static RP.
  7. Click Apply.
  8. Click Yes.
