Feature |
Product |
Release introduced |
Release deprecated |
NTPv3 client |
5320 Series |
Not Supported |
Not Applicable |
5420 Series |
Not Supported |
Not Applicable |
5520 Series |
Not Supported |
Not Applicable |
5720 Series |
Not Supported |
Not Applicable |
VSP 4450 Series |
VSP 4000 4.0 |
VOSS 8.2 |
VSP 4900 Series |
VOSS 8.1 |
VOSS 8.2 |
VSP 7200 Series |
VOSS 4.2.1 |
VOSS 8.2 |
VSP 7400 Series |
VOSS 8.0 |
VOSS 8.2 |
VSP 8200 Series |
VSP 8200 4.0 |
VOSS 8.2 |
VSP 8400 Series |
VOSS 4.2 |
VOSS 8.2 |
VSP 8600 Series |
VSP 8600 4.5 |
Not Applicable |
XA1400 Series |
VOSS 8.0.50 |
VOSS 8.2 |
NTPv3 with SHA authentication |
5320 Series |
Not Supported |
Not Applicable |
5420 Series |
Not Supported |
Not Applicable |
5520 Series |
Not Supported |
Not Applicable |
5720 Series |
Not Supported |
Not Applicable |
VSP 4450 Series |
VOSS 5.1 |
VOSS 8.2 |
VSP 4900 Series |
VOSS 8.1 |
VOSS 8.2 |
VSP 7200 Series |
VOSS 5.1 |
VOSS 8.2 |
VSP 7400 Series |
VOSS 8.0 |
VOSS 8.2 |
VSP 8200 Series |
VOSS 5.1 |
VOSS 8.2 |
VSP 8400 Series |
VOSS 5.1 |
VOSS 8.2 |
VSP 8600 Series |
VSP 8600 4.5 |
Not Applicable |
XA1400 Series |
VOSS 8.0.50 |
VOSS 8.2 |
NTPv4 client for IPv4 |
5320 Series |
Fabric Engine 8.6 |
Not Applicable |
5420 Series |
VOSS 8.4 |
Not Applicable |
5520 Series |
VOSS 8.2.5 |
Not Applicable |
5720 Series |
Fabric Engine 8.7 |
Not Applicable |
VSP 4450 Series |
VOSS 7.0 |
Not Applicable |
VSP 4900 Series |
VOSS 8.1 |
Not Applicable |
VSP 7200 Series |
VOSS 7.0 |
Not Applicable |
VSP 7400 Series |
VOSS 8.0 |
Not Applicable |
VSP 8200 Series |
VOSS 7.0 |
Not Applicable |
VSP 8400 Series |
VOSS 7.0 |
Not Applicable |
VSP 8600 Series |
VSP 8600 8.0 |
Not Applicable |
XA1400 Series |
Not Supported |
Not Applicable |
NTPv4 client for IPv6 |
5320 Series |
Fabric Engine 8.6 |
Not Applicable |
5420 Series |
VOSS 8.4 |
Not Applicable |
5520 Series |
VOSS 8.2.5 |
Not Applicable |
5720 Series |
Fabric Engine 8.7 |
Not Applicable |
VSP 4450 Series |
VOSS 7.0 |
Not Applicable |
VSP 4900 Series |
VOSS 8.1 |
Not Applicable |
VSP 7200 Series |
VOSS 7.0 |
Not Applicable |
VSP 7400 Series |
VOSS 8.0 |
Not Applicable |
VSP 8200 Series |
VOSS 7.0 |
Not Applicable |
VSP 8400 Series |
VOSS 7.0 |
Not Applicable |
VSP 8600 Series |
VSP 8600 8.0 |
Not Applicable |
XA1400 Series |
Not Supported |
Not Applicable |
NTPv4 master and restrict |
5320 Series |
Fabric Engine 8.6 |
Not Applicable |
5420 Series |
VOSS 8.4 |
Not Applicable |
5520 Series |
VOSS 8.2.5 |
Not Applicable |
5720 Series |
Fabric Engine 8.7 |
Not Applicable |
VSP 4450 Series |
VOSS 8.0 |
Not Applicable |
VSP 4900 Series |
VOSS 8.1 |
Not Applicable |
VSP 7200 Series |
VOSS 8.0 |
Not Applicable |
VSP 7400 Series |
VOSS 8.0 |
Not Applicable |
VSP 8200 Series |
VOSS 8.0 |
Not Applicable |
VSP 8400 Series |
VOSS 8.0 |
Not Applicable |
VSP 8600 Series |
VSP 8600 8.0 demonstration feature |
Not Applicable |
XA1400 Series |
Not Supported |
Not Applicable |
NTP Authentication Key Obfuscation |
5320 Series |
Fabric Engine 8.8 |
Not Applicable |
5420 Series |
Fabric Engine 8.8 |
Not Applicable |
5520 Series |
Fabric Engine 8.8 |
Not Applicable |
5720 Series |
Fabric Engine 8.8 |
Not Applicable |
VSP 4450 Series |
VOSS 8.8 |
Not Applicable |
VSP 4900 Series |
VOSS 8.8 |
Not Applicable |
VSP 7200 Series |
VOSS 8.8 |
Not Applicable |
VSP 7400 Series |
VOSS 8.8 |
Not Applicable |
VSP 8200 Series |
VOSS 8.8 |
Not Applicable |
VSP 8400 Series |
VOSS 8.8 |
Not Applicable |
VSP 8600 Series |
VSP 8600 8.1 |
Not Applicable |
XA1400 Series |
VOSS 8.8 |
Not Applicable |
DEMO FEATURE - NTPv4 Master Mode and Restrict is a demonstration feature on some products. Demonstration features are provided for testing purposes. Demonstration features are for lab use only and are not for use in a production environment. For more information, see Fabric Engine and VOSS Feature Support Matrix.
The following sections provide information on NTPv3 and NTPv4. If your platform supports both versions, the default is NTPv3.
Important
For NTPv4:
The switch can operate as both NTPv4 client and NTPv4 server.
The server selection algorithm can deem a server to be unfit to sync even though there is connectivity.
It can take several iterations (intervals) for the server to sync.
You must configure a Segmented Management Instance on applicable switches before you use NTPv4.
