View the port members in the specified MLT, or for all MLTs.
The show mlt [<1-512>] command displays remote port members only if the MLTs are configured on vIST peers that use the same MLT ID.
If the MLT is between two devices that use the same MLT ID, but they are not vIST peers, show mlt [<1-512>] does not display the remote port members in the output.
In this first example, MLT 512 is an MLT between two vIST peers with the same ID used on both peers. In this case, the output displays the remote port members.
Switch:1(config)# show mlt 512
Mlt Info
PORT MLT MLT PORT VLAN
MLTID IFINDEX NAME TYPE ADMIN CURRENT MEMBERS IDS
512 6655 MLT-512 trunk norm norm 1/24 1000 2000
DESIGNATED LACP LACP
MLTID IFINDEX PORTS ADMIN OPER
512 6655 null disable down
WHICH PORTS
WHERE LOCAL REMOTE PROGRAMMED
MLTID NAME CREATED PORT MEMBERS PORT MEMBERS IN DATA PATH
512 MLT-512 LOCAL 1/24 3/24 LOCAL
ENCAP
MLTID IFINDEX DOT1Q LOSSLESS
512 6655 enable disable
In this second example, MLT 1 is an MLT between two devices that are not vIST peers so the output does not display the remote port members.
Switch:1(config)# show mlt 1
Mlt Info
1 6144 MLT-1 trunk norm norm 1/5 1000 2000
1 6144 1/5 disable down
WHICH PORTS
1 MLT-1 LOCAL 1/5 LOCAL
ENCAP
1 6144 enable disable
Variable definitions
Use the data in the following table to use the show mlt error collision command.
Variable |
Value |
<1-512> |
Specifies the MLT ID. The value ranges from 1–512. |
