Use the following procedure to configure an OVSDB controller ID, IP address, protocol, and port.
- Click OVSDB.
- Click the Controller tab.
- Click Insert.
- In the Id field, assign a unique index value to this controller.
- In the IpAddr field, enter the IP address of this controller.
- In the Protocol field, select tcp or ssl.
- In the Port field, enter a port number.
- Click Insert.
Controller field descriptions
Use the data in the following table to use the Controller tab.
Name |
Description |
Id |
Specifies an ID number for a controller. Value range of 1 to 100. |
IpAddr |
Specifies the IP address of a controller. Type an IP address in A.B.C.D format. |
Protocol |
Specifies the communications protocol for the controller. Select tcp or ssl. |
Port |
Specifies the communications port for the controller. Value range of 1 to 65535. |
