Use the following procedure to create graphs for chassis statistics.
- In the Device Physical View, select the chassis.
 - Click Chassis.
 - Click the System tab.
System Field Descriptions
The following table describes the fields on the System tab.
 Name  |
 Description  |
 MemUsed  |
 The percentage of memory space used. Only the AbsoluteValue column is valid in the System tab. All other columns display as N/A because they are percentages and not actual memory counters.  |
 MemFree  |
 The amount in kilobytes of free memory.  |
 CpuUtil  |
 Percentage of CPU utilization.  |
