Use the following procedure to clear Fabric RSPAN (Mirror to I-SID) statistics of packets mirrored into the specified mirroring I-SID or all mirroring I-SIDs on the BEB.
Switch:1>enable Switch:1#configure terminal
Clear all Fabric RSPAN statistics:
Switch:1(config)# clear isid-mirroring stats
Clear all Fabric RSPAN (Mirror to I-SID) statistics of packets mirrored into the specified mirroring I-SID
Switch:1(config)# clear isid-mirroring stats monitor-isid-offset 1
The following table defines parameters for the clear isid-mirroring stats command.
Variable |
Value |
monitor-isid-offset WORD<1–1024> |
Specifies the offset ID that is mapped to the actual monitor I-SID where packets are mirrored. Monitor I-SID = base monitor I-SID + offset ID. The range of the monitor-isid-offset is 1 to 1000. The base monitor I-SID is 16776000. |
