Use the following commands to check IGMP information.
enable
show ip igmp interface [gigabitethernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}][vlan <1-4059>[vrf WORD<1–16>][vrfids WORD<0–512>]
Ensure that the output displays routed-spb under MODE.
show ip igmp cache [vrf WORD<1–16>][vrfids WORD<0–512>]
show ip igmp group [count][member-subnet default|{A.B.C.D/X}][vrf WORD<1–16>][vrfids WORD<0–512>]
show ip igmp sender [count][member-subnet default|{A.B.C.D/X}][vrf WORD<1–16>][vrfids WORD<0–512>]
Display IGMP information for Layer 3 VSN with IP multicast over Fabric Connect:
Switch:#enable
Switch:1#show ip igmp interface vrf green
                         Igmp Interface - GlobalRouter
       QUERY              OPER            QUERY   WRONG            LASTMEM
IF     INTVL STATUS VERS. VERS QUERIER    MAXRSPT QUERY JOINS ROBUST QUERY MODE
V100   125    activ  2     2   0.0.0.0    100     0     0     2      10   routed-spb
1 out of 1 entries displayed
               Switch:1#show ip igmp interface vlan 2
                                  Vlan Ip Igmp
VLAN QUERY QUERY ROBUST VERSION LAST  PROXY  SNOOP  SNOOP    SSM    UPnP   FAST   FAST
ID   INTVL MAX                  MEMB  SNOOP  ENABLE ORIGIN   SNOOP  FILTER LEAVE  LEAVE
           RESP                 QUERY ENABLE                 ENABLE ENABLE ENABLE PORTS
2   125   100   2      2       10    false   false   RADIUS   false   false   false
VLAN SNOOP   SNOOP           DYNAMIC   COMPATIBILITY EXPLICIT UPnP
ID   QUERIER QUERIER         DOWNGRADE MODE          HOSTS    FILTER
     ENABLE  ADDRESS         VERSION                 TRACKING ADDRESS
2   false   0.0.0.0         enable    disable       disable  239.255.255.250/32
               Switch:1# show ip igmp sender vrf vrf1
		 IGMP Sender - VRF vrf1
                              PORT/
GRPADDR   IFINDEX    MEMBER    MLT    STATE      L2ISID SCOPEISID  DATAISID
224.1.1.4  Vlan 10  192.2.0.1  1/18/1  NOTFILTERED   0  10010    16000001
224.1.1.4  Vlan 10  192.2.0.1  1/18/1  NOTFILTERED   0  10010    16000004
224.1.1.6  Vlan 10  192.2.0.1  1/18/1  FILTERED      0  10010    16000010
224.1.1.7  Vlan 10  192.2.0.1  1/18/1  FILTERED      0  10010    16000009
224.1.1.8  Vlan 10  192.2.0.1  1/18/1  NOTFILTERED   0  10010     210
5 out of 5 entries displayed
               Switch:1# show ip igmp group vrf green
                           IGMP Group - GlobalRouter
GRPADDR         INPORT          MEMBER          EXPIRATION TYPE
233.252.0.1    V501-9/16       192.2.0.1      204        Dynamic
233.252.0.2    V501-9/16       192.2.0.1      206        Dynamic
233.252.0.3    V501-9/16       192.2.0.1      206        Dynamic
233.252.0.4    V501-9/16       192.2.0.1      207        Dynamic
233.252.0.5    V501-9/16       192.2.0.1      204        Dynamic
233.252.0.6    V501-9/16       192.2.0.1      209        Dynamic
233.252.0.7    V501-9/16       192.2.0.1      206        Dynamic
233.252.0.8    V501-9/16       192.2.0.1      206        Dynamic
233.252.0.9    V501-9/16       192.2.0.1      211        Dynamic
233.252.0.10   V501-9/16       192.2.0.1      207        Dynamic
10 out of 10 group Receivers displayed
Total number of unique groups 10
