This procedure does not apply to VSP 8600 Series and XA1400 Series.Perform this procedure to disable Auto-sense on one or more ports. You also have the option to disable Auto-sense on the port but retain the configuration that the system applied dynamically. The dynamic configuration becomes a manual configuration and is visible in the show running-config output.
If you select more than one port, the format of the tab changes to a table-based tab.
