Feature |
Product |
Release introduced |
Link Debounce |
5320 Series |
Fabric Engine 8.6 |
5420 Series |
VOSS 8.5 |
5520 Series |
VOSS 8.5 |
5720 Series |
Fabric Engine 8.7 |
VSP 4450 Series |
VOSS 8.4.2 |
VSP 4900 Series |
VOSS 8.4.2 |
VSP 7200 Series |
VOSS 8.5 |
VSP 7400 Series |
VOSS 8.4.2 |
VSP 8200 Series |
VOSS 8.5 |
VSP 8400 Series |
VOSS 8.5 |
VSP 8600 Series |
Not Supported |
XA1400 Series |
Not Supported |
In a WAN environment, when a carrier-side link failure occurs, switchover on the carrier side can take a few hundred milliseconds. During that time, a lag in the sending and receiving of packets can occur. Use Link Debounce to hold the connection path until the switchover is complete. You can configure Link Debounce on each port.
Link Debounce works only on Layer 1 protocol applications. Layer 2 / Layer 3 protocols make decisions based on how they receive packets. For example, STP makes the decision according to the lack of traffic and port up condition; OSPF and IS-IS can still fail adjacencies.
You cannot configure Link Debounce on Integrated Application Hosting (IAH ) ports (also known as Insight ports).
