Use the following procedure to display the next hop for the logical interface.
- Select the Logical Interfaces NextHop tab.
Logical Interfaces NextHop field descriptions
Use the data in the following table to use the Logical Interfaces NextHop tab.
| Name | Description |
| Id | Shows a unique value that identifies the logical interface tunnel. |
| Ip | Shows a unique value that identifies the next hop IP address of the logical interface tunnel. |
| DestIfIndex | Shows the next hop destination interface index to reach the next hop IP of the logical interface tunnel. |
| DestVid | Shows the next hop destination VLAN ID to reach the next hop IP of the logical interface tunnel. |
