This procedure only applies to VSP 4900 Series and VSP 7400 Series using Fabric IPsec Gateway.
Ensure IPsec fragmentation before encryption is disabled.
Perform this procedure to enable IPsec compression on Fabric IPsec Gateway Virtual Machine (VM).
By default, IPsec compression is disabled. You must enable IPsec compression on both ends of the adjacency.
enable
virtual-service WORD<1-128> console
Type CTRL+Y to exit the console.
set ipsec compression
