This procedure only applies to VSP 4450 Series.
View the OSPF advanced interface.
- Select OSPF.
- Select the Interface Advanced tab.
Interface Advanced field description
Use the data in the following table to use the OSPF Interface Advanced tab.
| Name | Description |
| Index | Indicates the Index of the OSPF interface. |
| Metric | Specifies the metric for the type of service (TOS) on this port. The value of the TOS metric is (10^9 / interface speed). The default is 1.
| AdvertiseWhenDown | Advertises the network on this port as up, even if the port is down. The default is false. After you configure a port with no link and enable AdvertiseWhenDown, it does not advertise the route until the port is active. Then, OSPF advertises the route even if the link is down. To disable advertising based on linkstates, disable AdvertiseWhenDown. |
| IfMtuIgnore | Specifies whether the interface ignores the global maximum transmission unit (MTU) configuration. To allow the switch to accept OSPF database description (DD) packets with a different MTU size, enable MtuIgnore. The interface drops incoming OSPF DD packets if their MTU is greater than 1500 bytes. |
