This procedure only applies to VSP 4900 Series and VSP 7400 Series.
Perform this procedure to configure CP Limit functionality to protect the switch from becoming congested by excess data flow through Extreme Integrated Application Hosting (IAH) ports.
- Select the IAH port you want to configure.
- Select the CP Limit tab.
- Select AutoRecoverPort.
- Select Apply.
CP Limit Field Descriptions
Use data in the following table to use the CP Limit tab.
| Name | Description |
| AutoRecoverPort | Enables or disables auto recovery of the Extreme Integrated Application Hosting port from action taken by CP Limit or the link flap features. The default is disabled. |
