This procedure only applies to the VSP 7400 Series.
- Enable multicast on the boundary nodes.
- Configure Multiprotocol Label Switching Virtual Private Network (MVPN) on the boundary nodes, for layer 3 VSN.
- Configure the same policies as the boundary node on the peer boundary nodes.
Perform this procedure to configure Multi-area SPB IPv4 routed multicast redistribution on the switch.
Configuring Multi-area SPB IPv4 routed multicast redistribution for home to remote direction:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis
Switch:1(config-isis)#multi-area ip redistribute routed-multicast home-to-remote
Switch:1(config-isis)#multi-area ip redistribute routed-multicast home-to-remote route-map test
Switch:1(config-isis)#multi-area ip redistribute routed-multicast home-to-remote enable
Switch:1(config-isis)#show isis multi-area ip redistribute routed-multicast home-to-remote
      ISIS Multiarea Redistribute List for routed multicast - GlobalRouter
DIRECTION            ENABLE     RPOLICY
home-to-remote       TRUE       test
Switch:1(config-isis)#isis multi-area ip apply redistribute routed-multicast home-to-remote
The following table defines parameters for the multi-area ip redistribute routed-multicast and the isis multi-area ip apply redistribute routed-multicast command.
| Variable | Value |
| enable | Enables Multi-area SPB IPv4 routed multicast redistribution. |
| home-to-remote | Specifies the IPv4 routed multicast redistribution configuration for home to remote direction. |
| remote-to-home | Specifies the IPv4 routed multicast redistribution configuration for remote to home direction. |
| route-map WORD<1-64> | Specifies the name of the route policy. |
| vrf WORD<1-16> | Specifies the multicast routing redistribution configuration for specific VRF instance. |
