You must enable port lock before you lock or unlock a port.
Use the port lock feature to administratively lock a port or ports to prevent other users from changing port parameters or modifying port action. You cannot modify locked ports until you first unlock the port.
 - Click General.
 - Click the Port Lock tab.
 - In the LockedPorts box, click the ellipsis (...) button.
 - Click the desired port or ports.
 - Click Ok.
 - In the Port Lock tab, click Apply.
Port Lock field descriptions
Use the data in the following table to use the Port Lock tab.
 Name  |
 Description  |
 Enable  |
 Activates the port lock feature. Clear this check box to unlock ports. The default is disabled.  |
 LockedPorts  |
 Lists the locked ports. Click the ellipsis (...) button to select the ports you want to lock or unlock.  |
