Perform this task to run a virtual machine (VM) command from the NOS CLI.
enable
configure terminal
virtual-service WORD<1-128> exec-command WORD<1-256>
virtual-service WORD<1-128> figw-cli WORD<1-256>
To use this command, the Fabric IPsec Gateway image must be at least 5.0.0.0.
From NOS, list the contents of the home/rwa/configs directory in the Fabric IPsec Gateway VM:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#virtual-service figw exec-command "ls /home/rwa/configs" config.cfg figw_cli.log shadov.txt
From NOS, configure the source VLAN ID for the IPsec tunnel in the Fabric IPsec Gateway VM:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#virtual-service figw figw-cli "set global ipsec-tunnel-src-vlan 71"
