Use this procedure to view or configure FA I-SID-to-VLAN assignment information.
- Click Fabric Attach.
- Click the Assignment tab.
- If you make configuration changes, click Apply to save changes.
Assignments Field Descriptions
Use the data in the following table to use the Assignments tab.
| Name | Description |
| IfIndex | Specifies the interface identifier of the I-SID-to-VLAN assignment. |
| Isid | Specifies the I-SID value of the I-SID-to-VLAN assignment. |
| Vlan | Specifies the VLAN ID component of the I-SID-to-VLAN assignment. |
| State | Specifies the current state of the I-SID-to-VLAN assignment. It can be one of the following values:
| Origin | Specifies the origin information of the I-SID-to-VLAN assignment. |
| Isid name | Specifies the I-SID name. |
