Use the Addresses tab to view IP addresses (and their associated router interfaces) from one central location.
- Click IP.
- Click the Addresses tab.
Addresses field descriptions
Use the data in the following table to use the Addresses tab.
| Name | Description |
| Interface | Specifies the router interface.
| Ip Address | Specifies the IP address of the router interface. |
| Net Mask | Specifies the subnet mask of the router interface. |
| BcastAddrFormat | Specifies the IP broadcast address format used on this interface; that is, whether 0 (zero) or one is used for the broadcast address. The switch uses 1. |
| ReasmMaxSize | Specifies the size of the largest IP packet that this interface can reassemble from incoming fragmented IP packets. |
| VlanId | Identifies the VLAN associated with this entry. This value corresponds to the lower 12 bits in the IEEE 802.1Q VLAN tag. |
| BrouterPort | Indicates whether this is a brouter port (as opposed to a routable VLAN). |
| MacOffset | Specifies a number by which to offset the MAC address of the VLAN from the chassis MAC address. This ensures that each IP address has a different MAC address. |
