Using PIM Debugging Commands
Use Protocol Independent Multicast (PIM) traces to aid in PIM troubleshooting.
The following table defines parameters for the debug ip pim command.
 Variable  |
 Value  |
 assert  |
 Displays the assert debug traces. The default is false (disabled).  |
 bstrap  |
 Displays bootstrap debug traces. The default is false (disabled).  |
 group {A.B.C.D}  |
 Displays debug traces from a specific group IP address. The default is 0.0.0.0 (disabled).  |
 hello  |
 Displays hello debug traces. The default is false (disabled).  |
 joinprune  |
 Displays join and prune debug traces. The default is false (disabled).  |
 pimdbglog  |
 Logs debug traces. The default is false (disabled).  |
 pimdbgtrace  |
 Displays PIM debug traces. The default is false (disabled).  |
 rcv-dbg-trace  |
 Displays trace messages received by the switch. The default is false (disabled).  |
 register  |
 If enabled, the system displays register debug traces. The default is false (disabled).  |
 regstop  |
 Displays register stop debug traces. The default is false (disabled).  |
 rp-adv  |
 Displays RP advertisement debug traces. The default is false (disabled).  |
 send-dbg-trace  |
 Displays trace messages forwarded by the switch. The default is false (disabled).  |
 source {A.B.C.D}  |
 Displays debug traces from a specific source IP address. The default is 0.0.0.0 (disabled).  |
