BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see Fabric Engine and VOSS Feature Support Matrix.
Use this procedure to display global configuration information for BFD.
The following example displays global configuration information for BFD on an IPv4 interface.
Switch:1>show ip bfd
BFD information - GlobalRouter
BFD Version : 1
Admin Status : TRUE
Trap Enable : FALSE
Total session number : 1
UP: 1, DOWN: 0, AdminDown: 0, Init: 0
The following table defines parameters for the show ip bfd command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF instance by VRF name. |
vrfids WORD<0-512> |
Specifies a VRF or range of VRFs by ID. |
