The following table defines parameters for the show isis lsdb command.
| Variable | Value |
| detail | Displays detailed information about the IS-IS Link State database. |
| home | Displays the IS-IS LSDB information that the system configures in the home area. |
| level {l1, l2, l12} | Displays information on the IS-IS level. The IEEE 802.1aq standard currently only defines the use of one hierarchy, Level 1. Level 2 function is disabled. |
| local | Displays information on the local LSDB. |
| lspid <xxxx.xxxx.xxxx.xx-xx> | Specifies information about the IS-IS Link State database by LSP ID. |
| remote | Displays the IS-IS LSDB information that the system configures in the remote area. |
| sub-tlv <1–3> | Specifies information about the IS-IS Link State database by sub-TLV. |
| sysid <xxxx.xxxx.xxxx> | Specifies information about the IS-IS Link State database by System ID. |
| tlv <1–236> | Specifies information about the IS-IS Link State database by TLV. |
