Use this procedure to view the ingress policer statistics. The system displays individual policer statistics for specific ports to manage network performance.
This procedure only applies to VSP 8600 Series, VSP 4450 Series and XA1400 Series.
Switch:1# show interfaces gigabitethernet statistics policer 1/3
QoS Ingress Port Policer Stats
PORT TOTAL TOTAL YELLOW RED
NUM PKTS BYTES BYTES BYTES
1/3 420 31628 0 0
Use the data in the following table to use the show interfaces gigabitethernet statistics policer command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
