Perform this procedure to create an IPv6 CLIP interface and associate it with a specific VRF.
Switch:1#show ipv6 interface loopback
Loopback Ipv6 Interfaces
IF VRF Descr VLAN PHYSICAL ADMIN OPER TYPE MTU HOP REACHABLE RETRANSMIT IPSEC
INDX NAME ADDRESS STATE STATE LMT TIME TIME STATE
1348 GlobalRouter CLIPv6-5 --00:00:00:00:00:05 enable up ETHER 1500 64 30000 1000 disable
Loopback IPv6 Addresses
IPV6 ADDRESS/PREFIX LENGTH LOOPBACK-ID TYPE ORIGIN STATUS NAME
2001:db8:0:0:0:0:0:ffff/32 C-5 UNICAST MANUAL PREFERRED INF INF EXTREMESERVER_2
Legend: NA - Information not available
1 out of 1 Total Num of Interface Entries displayed.
1 out of 1 Total Num of Address Entries displayed.
Use the data in the following table to use the ipv6 commands.
Variable |
Value |
ospf <1-256> enable Note:
Exception: Only supported on VSP 8600 Series. |
Enables OSPFv3 instance on the CLIP interface. |
WORD<1–256> |
Specifies the CLIP interface ID. |
WORD<0–255> |
Specifies the IPv6 address. |
vrf WORD<1–16> |
Specifies the VRF name. |
WORD<0–64> |
Specifies the I-SID name associated with the IPv6 address. |
