This procedure does not apply to VSP 8600 Series.
Use this task to view TCP statistics for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Stats.
- Select the IP/IPv6 TCP tab.
IP/IPv6 TCP Field Descriptions
Use the data in the following table to use the IP/IPv6 TCP tab.
| Name | Description |
| IPVersion | Shows the IP address version as ipv4 or ipv6. |
| ActiveOpens | Shows the active open TCP connections statistics. |
| PassiveOpens | Shows the passive open TCP connections statistics. |
| AttemptFails | Shows the TCP connection attempt failures statistics. |
| EstabResets | Shows the TCP connection esablished resets statistics. |
| InSegs | Shows the input segments statistics. |
| OutSegs | Shows the output segments statistics. |
| RetransSegs | Shows the retransmit segments statistics. |
| InErrs | Shows the input checksum errors statistics. |
| OutRsts | Shows the output resets statistics. |
| InCsumErrors | Shows the input checksum errors statistics. |
| Clear | Specifies to clear the statistics. Default is false. |
