View global VRF status information to determine the number of VRFs that are configured and active.
- Click VRF.
- Click the Global Status tab.
Global Status field descriptions
Use the data in the following table to use the Global Status tab.
Name |
Description |
ConfigNextAvailableVrfId |
Specifies the number of the next available Virtual Router ID (index). |
ConfiguredVRFs |
Specifies the number of VRFs configured on this network element. |
ActiveVRFs |
Specifies the number of VRFs that are active on the network element. These are VRFs for which the OperStatus is up. |
