View UDP Endpoints to confirm correct configuration.
Change the VRF instance as required to view UDP endpoint information on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
You can use UDP endpoint information to display local and remote UDP activity.
Since UDP is a protocol used to establish connectionless network sessions, you need to monitor local and remote UDP activity and to know which applications are running over UDP.
You can determine which applications are active by checking the port number.
Processes are further identified with a UDP session to allow for the multiplexing of a port mapping for UDP.
- Click TCP/UDP.
- Click the UDP Endpoints tab.
UDP Endpoints field descriptions
Use the data in the following table to use the UDP Endpoints tab.
| Name | Description |
| LocalAddressType | Displays the local address type (IPv6 or IPv4). |
| LocalAddress | Displays the local IPv6 address. |
| LocalPort | Displays the local port number. |
| RemoteAddressType | Displays the remote address type (IPv6 or IPv4). |
| RemoteAddress | Displays the remote IPv6 address. |
| RemotePort | Displays the remote port number. |
| Instance | Distinguishes between multiple processes connected to the UDP endpoint. |
| Process | Displays the ID for the UDP process. |
