Perform the following procedure to commit an upgrade.
The software commit functionality for software upgrades allows maximum time set by the commit timer (the default is 10 minutes) to ensure that the upgrade is successful. If you enable the auto-commit option, the system automatically commits to the new software version after the commit timer expires.
enable
configure terminal
sys software commit-time <10-60>
The default is 10 minutes.
VSP 8600 Series default is 15 minutes.
software reset-commit-time [<1–60>]
software commit
Important
If you disable the auto-commit feature, you must run the software commit command manually before the commit timer expires to commit the new software version, otherwise the system restarts automatically to the previous (committed) version. By default, auto-commit is enabled.
