Create an IPv6 VPN instance to advertise IPv6 routes from a VRF to Shortest Path Bridging MAC (SPBM) network.
You must configure the required SPBM IS-IS infrastructure.
The VRF must exist.
- In the navigation tree, expand .
- Select IPv6-VPN.
- Select the VPN tab.
- Select Insert.
- Select [...], and then select a VRF from the list.
- Select OK.
- Select Insert.
- In the IsidNumber column, double-click the 0 value, and then enter the service instance identifier (I-SID) to assign to the IPv6-VPN.
- In the Enable column, double-click the value and select true or false from the drop-down list.
- Select Apply.
VPN Field Descriptions
Use the data in the following table to use the VPN tab.
Name |
Description |
VrfId |
Specifies the ID of the VRF to configure. |
Enable |
Enables or disables the IPv6 VPN instance on the VRF. The default is disabled. |
IsidNumber |
Specifies the I-SID to associate with the IPv6 VPN. By default, no I-SID is assigned. |
IsidName Note:
This field is not supported on all hardware platforms. |
Specifies the name of the I-SID. |
