Use the following procedure to view IPv6 Mroute route information.
- In the navigation pane, expand the following folders: .
- Click IPv6 Mroute.
- Click the Route tab.
IPv6 Multicast Route field descriptions
Use the data in the following table to use the Route tab.
| Name | Description |
| Group | Displays the IPv6 multicast group for this entry that specifies a next hop on an outgoing interface. |
| Source | Displays the network address that, when combined with the corresponding next hop SourceMask value, identifies the source for this entry that specifies a next hop on an outgoing interface. |
| SourceMask | Displays the network mask that, when combined with the corresponding next hop Source value, identifies the source for this entry that specifies a next hop on an outgoing interface. |
| UpStreamNeighbor | Shows the address of the upstream neighbor from which the IPv6 datagrams from these sources are received. |
| IfIndex | Displays the slot and port number or VLAN ID for this entry. |
| ExpiryTime | Displays the minimum amount of time that remains before this entry ages out. The value 0 indicates that the entry is not subject to aging. |
| Protocol | Displays the protocol as one of the following:
