Use the following procedure to configure the minimum required SPBM and IS-IS parameters using the auto-nni command to have the node create an IS-IS interface, attach the interface to an SPBM instance, and then enable IS-IS on the port interface.
This procedure is only for the port interface. The auto-nni command is not supported on the MLT interface and the Fabric Extend Logical Interface.
The auto-nni command provides a quick and simple way to configure the IS-IS interface. You can use the auto-nni command instead of the following existing IS-IS commands on the physical (port) interface:
isis
isis spbm instance
isis enable
The existing commands are still available and you have the option to use the new command or the three existing commands. If you need to modify any of the default parameters under isis or isis spbm instance , use isis and isis spbm instance constructs even if you created the interface with the auto-nni command.
enable
configure terminal
spbm
router isis
spbm <1–100>
spbm <1–100> b-vid {<vlan-id [-vlan-id][,...]} [primary <1-4059>]
spbm <1–100> nick-name <x.xx.xx>
Although it is not strictly required for SPBM operation, you should change the IS-IS system ID from the default B-MAC value to a recognizable address to easily identify a switch (Log on to IS-IS Router configuration mode and use the system-id <xxxx.xxxx.xxxx> command). This helps to recognize source and destination addresses for troubleshooting purposes.
manual-area <xx.xxxx.xxxx...xxxx>
exit
vlan create <2-4059> type spbm-bvlan
interface {GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}| mlt <1–512> }
auto-nni
exit
router isis enable
show isis spbm
show isis
show isis interface
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#spbm Switch:1(config)#router isis Switch:1(config-isis)#spbm 1 Switch:1(config-isis)#spbm 1 b-vid 10,20 primary 10 Switch:1(config-isis)#spbm 1 nick-name 1.11.16 Switch:1(config-isis)#manual-area c0.2000.000.00 Switch:1(config-isis)#exit Switch:1(config)#interface gigabitethernet 1/21 Switch:1(config-if)#auto-nni Switch:1(config-if)#exit Switch:1(config)#vlan create 10 type spbm-vlan Switch:1(config)#vlan create 20 type spbm-vlan Switch:1(config)#router isis enable Switch:1(config)#show isis spbm
ISIS SPBM Info
SPBM B-VID PRIMARY NICK LSDB IP IPV6 MULTICAST SPB-PIM-GW STP-MULTI
INSTANCE VLAN NAME TRAP HOMING
1 4051-4052 4051 disable disable disable enable disable enable
ISIS SPBM SMLT Info
SPBM SMLT-SPLIT-BEB SMLT-VIRTUAL-BMAC SMLT-PEER-SYSTEM-ID
INSTANCE
1 primary 00:00:00:00:00:00
Total Num of SPBM instances: 1
Switch:1>show isis
ISIS General Info
AdminState : enabled
RouterType : Level 1
System ID : 0014.c7e1.33df
Max LSP Gen Interval : 900
Metric : wide
Overload-on-startup : 20
Overload : false
Csnp Interval : 10
PSNP Interval : 2
Rxmt LSP Interval : 5
spf-delay : 100
Router Name : Switch1
ip source-address : 41.41.41.100
ipv6 source-address : 41:0:0:0:0:0:0:100
ip tunnel source-address : 11.11.12.11
Tunnel vrf : spboip
ip tunnel mtu : 1950
Num of Interfaces : 2
Num of Area Addresses : 1
inband-mgmt-ip :
backbone : disabled
Dynamically Learned Area : 00.0000.0000
FAN Member : No
Hello Padding : enabled
Multi-Area OperState : disabled
Multi-Area Flags : home-always-up
Switch:1# show isis interface
ISIS Interfaces
IFIDX TYPE LEVEL OP-STATE ADM-STATE ADJ UP-ADJ SPBM-L1 OP-SPBM- ORIGIN AREA AREA-NAME
-METRIC L1-METRIC
Mlt2 pt-pt Level 1 UP UP 1 1 10 (A) 10 CONFIG HOME area-9.00.02
Port1/21 pt-pt Level 1 UP UP 1 1 10 (A) 10 CONFIG HOME area-9.00.02
Home: 2 out of 2 Total Num of ISIS Interfaces
Legend:
(A): l1 metric is automatically updated based on detected interface speed.
