The following figure illustrates the components on the rear panel of the XA1440 and XA1480. Slot 1 is used for all of the ports.
DC power adapter input
Power button
Micro USB console port used to connect a terminal and perform local management.
RJ45 Console port used to connect a terminal and perform local management.
USB Type A ports for access to external storage.
RJ45 10/100/1000BASE-T Ethernet ports
10G SFP+ Ethernet ports
