This procedure does not apply to VSP 8600 Series.
Use this task to view IP address statistics for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Stats.
- Select the IP tab.
- To clear IP statistics, select Clear Stats.
- To clear IP counters, select Clear Counters.
IP Field Descriptions
Use the data in the following table to use the IP tab.
| Name | Description |
| InReceives | Shows the inbound packet statistics. |
| InHdrErrors | Shows the inbound packets with header errors statistics. |
| InAddrErrors | Shows the inbound packets with address errors statistics. |
| InUnknownProtos | Shows the inbound packets with unknown protocols statistics. |
| InDiscards | Shows the inbound packets discarded statistics. |
| InDelivers | Shows the inbound packets delivered statistics. |
| OutRequests | Shows the outbound packet requests statistics. |
| OutDiscards | Shows the outbound packets discarded statistics. |
| OutNotRoutes | Shows the outbound packets with no routes statistics. |
| ForwDatagrams | Shows the forwarded datagram packets statistics. |
| ReasmTimeout | Shows the packet reassembly timeouts statistics. |
| ReasmReqds | Shows the packet reassembly requests statistics. |
| ReasmOKs | Shows the successfully reassembled packets statistics. |
| ReasmFails | Shows the failed reassembled packets statistics. |
| FragOKs | Shows the successfully fragmented packets statistics. |
| FragFails | Shows the failed fragmented packets statistics. |
| FragCreates | Shows the fragments created statistics. |
