View information about the license file for the switch.
- Click Chassis.
- Click the License tab.
License field descriptions
Use the data in the following table to use the License tab.
Name |
Description |
FileName |
Indicates the file name of the current license. Note:
If this field is empty it indicates that there is no license installed on the switch. |
LicenseType |
Indicates the level type of the current license. |
DurationType |
Indicates the duration type of the current license. |
RemainingDays |
Indicates the days left before the factory default trial period or subscription license expires. Note:
For other license types, the field displays 0. |
GenerationTime |
Indicates the date on which the license file was generated. Note:
If there is no license installed on the system, this field displays 0000000000000000 H. |
ExpirationTime |
Indicates the date on which the license file expired. Note:
System Field Descriptions
Use the data in the following table to use the System tab.
Name |
Description |
sysDescr |
Shows the system assigned name and the software version. |
sysUpTime |
Shows the elapsed time since the system last started. |
sysContact |
Configures the contact information. |
sysName |
Configures the name of this device. |
sysLocation |
Configures the physical location of this device. |
VirtualIpAddr |
Configures the virtual IP address that the primary CPU advertises and stores in the switch configuration file. |
VirtualNetMask |
Configures the net mask of the virtual management IP address. |
VirtualIpv6Addr |
Specifies the virtual IPv6 address. |
VirtualIpv6PrefixLength |
Specifies the length of the virtual IPv6 address prefix (in bits). |
DnsDomainName |
Configures the default domain for querying the DNS server. |
LastChange |
Displays the time since the last configuration change. |
LastVlanChange |
Displays the time since the last VLAN change. |
LastStatisticsReset |
Displays the time since the statistics counters were last reset. |
LastRunTimeConfigSave |
Displays the last run-time configuration saved. |
DefaultRuntimeConfigFileName |
Displays the default Run-time configuration file directory name. |
ConfigFileName |
Specifies the name of a new configuration file. |
ActionGroup1 |
Performs one of the following actions:
LicenseFileName Note:
Exception: only supported on the VSP 8600 Series and the XA1400 Series. |
Specifies the name of the license file in the /intflash directory. |
ActionGroup2 |
Specifies the following action: resetlstStatCounters—Resets the IST statistic counters |
ActionGroup3 |
Can be the following action:
ActionGroup4 |
Result |
Displays a message after you select Apply. |
LocatorLED Note:
Exception: only supported on VSP 4900 Series. |
Configures the system Locator LED on or off. The default is off. |
